Sada je: 14 lip 2026 05:15. | Zadnji put si ovdje bio: 14 lip 2026 05:15. Vremenska zona: UTC + 01:00 [ LJV]
Dalmat
Naslov: Re: FILMOVI preporuka Postano: 29 lip 2015 08:54 |
Sense8 je lijepo snimljen, ima dobru kameru, ali je razvučen i malo su se pogubili, kao da ni sami ne znaju što su htjeli...
Naslov: Postano: 29 lip 2015 11:17 |
Zapeo mi za oko stanford prison experiment,po traileru izgleda dobro
Naslov: Re: FILMOVI preporuka Postano: 02 srp 2015 01:20 |
mpix
Naslov: Filmovi Postano: 02 srp 2015 11:43 |
Pridružen: 04 ožu 2015 14:28 Postovi: 716 Lokacija: ZG
 Complete name : \Dune.mkv Format : Matroska Format version : Version 4 / Version 2 File size : 3.77 GiB Duration : 2h 16mn Overall bit rate mode : Variable Overall bit rate : 3 961 Kbps Encoded date : UTC 2015-07-02 07:26:05 Writing application : mkvmerge v7.8.0 ('River Man') 64bit built on Mar 27 2015 16:31:37 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.0 Format settings, CABAC : Yes Format settings, ReFrames : 3 frames Codec ID : V_MPEG4/ISO/AVC Duration : 2h 16mn Bit rate mode : Variable Bit rate : 3 512 Kbps Maximum bit rate : 25.0 Mbps Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 24.000 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.071 Stream size : 3.27 GiB (87%) Audio ID : 2 Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Format settings, Endianness : Big Codec ID : A_AC3 Duration : 2h 16mn Bit rate mode : Constant Bit rate : 448 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Stream size : 437 MiB (11%) Default : Yes Forced : No Text ID : 3 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Default : Yes Forced : No https://mega.co.nz/#!sZFAVAJY!Z5iyj75sE2UqbN8E-HwuMojHIwx6tYhavaT7Q9nCGvAhttps://mega.co.nz/#!pUFRURQC!CW3aUR3oGLAsvFUorZONUpQBcI39xx59yl8t3segILwhttps://mega.co.nz/#!4U9FxAiC!PFd7Ex7oCnnKW6Cp7_Fwy32iOdmD_jVoV1inzNXU8hYhttps://mega.co.nz/#!sNV0HIzK!D-jxBF7DgrbTbug3Bx60IEW6xty0U53hbQ0YDdjLIwE
_________________ "The camera is an instrument that teaches people how to see without a camera" - Dorothea Lang
Naslov: Re: FILMOVI preporuka Postano: 04 srp 2015 15:00 |
to je jedan loš film...serija je puno bolja.
Sappy
Naslov: Re: FILMOVI preporuka Postano: 05 srp 2015 03:12 |
Pridružen: 21 lip 2012 10:30 Postovi: 948 Lokacija: Osijek
The Longest Ride http://www.imdb.com/title/tt2726560/?ref_=nv_sr_1Tu i tamo bude snimljen neki filmić koji ostavi malo dublji trag... Iskreno takvi me filmovi (ljubići, drame tj. romase) previše ne zanimaju, još kad sam vidio "poster", kontam još jedno hillbilly kaubojsko američko preseravanje.., no dao sam si truda i pošto bolja polovica voli ljubiće.., ajd da i ja pogledam.., i nisam požalio.., daleko od toga, ovo je jedan od boljih filmova tog žanra.... - portrait of happinessTo je bilo za opuštanje na kraju dana... A s klinjom sa bio u kinu i pogledao Terminator Genisys - za sve ljubitelje Terminator franšize, ono do jaja...., napokon nastavak vrijedan Terminatora 2: Judgment Day, iako neće ponoviti ni sličan uspjeh, ali samo je jedan Švarcika...!!!
_________________  The world will know that free men stood against a tyrant, that few stood against many...
Naslov: Re: FILMOVI preporuka Postano: 05 srp 2015 17:15 |
mpix
Naslov: Re: FILMOVI preporuka Postano: 10 srp 2015 21:26 |
Naslov: Re: FILMOVI preporuka Postano: 14 srp 2015 00:13 |
http://www.imdb.com/title/tt1823672/?ref_=nv_sr_1nije nešto extra, al za izgubit vrijeme je dobar EDIT: prošlo sat vremena, kad se sleglo, i ja promislio, film je zabavan, drukčiji, podsjeća na District 9, 7.4/10 i da, vrlo malo sam pario dok sam gledao
Naslov: Re: FILMOVI preporuka Postano: 03 kol 2015 22:46 |
Trenutno korisnika: bot* i 57 gostiju. |
