Početna » Pero d.o.o.
 [ 1361 post(ov)a ]  Stranica Prethodna  1 ... 7, 8, 9, 10, 11, 12, 13 ... 137  Sljedeća
 Naslov: Re: www.fasttech.com
 Post Postano: 17 kol 2013 00:07
Pridružen: 21 srp 2013 21:15
Postovi: 111
macchiato je napisao:
uzeo sam i ja SVD. ja zadovoljan, nego muci me ovo. naruciti ili ne.
http://www.fasttech.com/products/1411/1 ... -cigarette
uzeti ovo ili jos jedan SVD. :kuc:
da znas da imam i ja dilemu uzeti još jedan SVD ali možda ipak pricekam novi itaste.nekako mi je baš lego. :kuc:
ZMAX/Chi You clone/ZNA 50
Taifun GT / Taifun GT/ Taifun GT
 Post Postano: 20 kol 2013 12:35
Pridružen: 29 lip 2013 13:27
Postovi: 324
Prenosim sa ECF-a
C/P:
I found this write up and thought it worth passing on.
"4:13pm Aug 14
CHI YOU CLONE SAFETY WARNING
Hello. Some of you know that I run a site called FatDaddyVapes.com. ..... I will not be carrying any of the new Chi You clones. All the Chi Yous clones on the market right now are made by one manufacturer. This includes the ones that Fasttech sells. I know the manufacturers and am actually friends with them. I tried stopping them but they said that there is already a lot of orders committed.
There are 3 flaws that could be disastrous.
1 – The adjustment screws pins on top are short. This was designed using protected batteries. If you are using unprotected batteries like most mechanical mod users, the pin will get loose when you try to make it fit. It might work but once unattended, or if placed on a vehicle with vibrations, could get lose, cut the battery insulation, and cause a short leading to a leak – or worse, an explosion. THIS COULD HAPPEN EVEN WITHOUT AN ATOMIZER AND THE SAFETY ON!!!
2 – The bottom cover/switch assembly wobbles. This WOULD (as opposed to “could”) also cause an accidental misfire. Again, fire, injury, or property damage risks as a result of leaking or explosion. This could happen only if an atomizer is attached. EVEN WITH THE SAFETY ON, IT WOULD STILL FIRE BECAUSE THE CONTACT ROD INSIDE IS ALSO TILTED!!!
3 – THE WORSE. The bottom cover does not have any insulation. If you use those gray Panasonic batteries, IT WILL FIRE AS SOON AS YOU GET THE CAP ON IF YOU HAVE AN ATOMIZER ON!!! The gray Panasonics do not have the extra insulation at the bottom. (The bottom is exposed.) Even other brands are susceptible to this is you microcoil or sub-ohm because the battery shrink tube shrinks when heated.
I found a fix for it. Unfortunately, I still need it manufactured – IN CHINA! Unless one of you guys can make me custom brass bolts or has access to specialized small machinery hardware. Message me if you could help me expedite this process.
If you already have one of these Chi Yous, make sure that you use protected batteries. Also, go to Home depot and buy O-rings to be placed on the inside perimeter of the bottom cover. After all your adjustments are done, LOCTITE (Blue) that damn switch so it won’t get loose!!!
VAPE SAFE!!!"
Link: http://www.e-cigarette-forum.com/forum/ ... -more.html
I²mods
 Post Postano: 22 kol 2013 11:55
Postovi: 324
https://www.fasttech.com/products/1/100 ... ubricating
Multi-Purpose High Thermostability Lubricating Grease
Details:
Suitable for lubricating cooling fan, precision instruments, printer, family equipment, etc
No poison and smell
ROTFLMAO!!!!
I²mods
 Post Postano: 22 kol 2013 12:09
Ili u prevodu vazelin. No taj vazelim se koristi za najmanje 1000 raznih primjena od kojih tebi bada na pamet samo jedna.
Naručio.
 Post Postano: 22 kol 2013 12:27
Postovi: 324
Znao sam da buš se javio, tako tako samo ti kupi i podmaži obiteljsku opremu. :plus:
I²mods
 Post Postano: 22 kol 2013 13:30
Postovi: 324
https://www.fasttech.com/products/1/100 ... izer-6-0ml
Interesantno
I²mods
 Post Postano: 22 kol 2013 13:50
igor je napisao:
https://www.fasttech.com/products/1/10005572/1436800-fogger-clear-tank-rebuildable-atomizer-6-0ml
Interesantno
Tu je prvenstveno važno kako konus naliježe na središnji "dimnjak" :hmm:
 Post Postano: 22 kol 2013 13:56
To je prvenstveno skupo. Ima puno bojih stvari na FT.
 Post Postano: 22 kol 2013 17:04
Postovi: 111
igor je napisao:
Interesantno
izgleda stvarno interesantno :hmm: cjena je malo veća ali....
 Post Postano: 22 kol 2013 17:15
Fogger by Jiangmen Yiloong Industrial Co., Ltd.
Atty je izgleda stvarno SS osim mozda dna s konektorom.
