 [ 6 post(ov)a ]
 Naslov: Joytech eVic-S (eVic v.2) prototype
 Post Postano: 11 ruj 2013 15:10
Pridružen: 29 lip 2013 13:27
Postovi: 324
Naišao sam danas na interesantnu informaciju iz Joytecha je izašla informacija da se radi na novom eVicu.
Citiram:
The next version of the eVic, the eVic-S, isn't so much a newer model as it as a different version of the current eVic. I don't know very much about it right now, but I do know that it is thinner and more durable than the current eVic, and is without the LCD screen (it's controlled either with the software or with button clicks to change the V/W.) I'm not sure, but I think the thinning down of the model is changing the head and body threads. I will have more on this later.
As I just started at the company, and am completely new to e-cigs, I know next-to-nothing about mod kits. I should check out some beginner posts here and get learned.
eVic-S is in design phase now. Slimmer, more durable, but at the same time, heavier.
Increased durability (along with weight)
Metal 360-degree direction wheel with tactile clicks
Larger LCD screen
Increased voltage/wattage outputs
Same thread size as eVic I
malo više informacija možete pronaći ovdje:
http://www.e-cigarette-forum.com/forum/evic/460918-evic-2-prototype.html
http://www.reddit.com/r/electronic_cigarette/comments/1l6u48/ladies_and_gentlemen_i_give_you_the_evic_ii/
I²mods
 Naslov: Re: Joytech eVic-S (eVic v.2) prototype
 Post Postano: 11 ruj 2013 16:07
oko Božića bude izašlo puno novih stvari, kad počne ludilo kupovine
čekam samo da još mobitel i MOD spoje u jedno i onda....
 Post Postano: 11 ruj 2013 16:53
Pridružen: 20 ruj 2012 14:00
Postovi: 1012
Hmmm.... Ovo bi moglo mene zanimati.
Još ćemo vidjeti je li stvarno što bolje od ovog evica što imam.
Težina mu je jedino minus jer je i ovako težak, a bit će još i teže.
 Post Postano: 07 ožu 2014 16:30
Pridružen: 07 ožu 2014 14:59
Postovi: 7
Lokacija: Visoko, Bosna i Hercegovina
dovoljno je reći Joytech i kraj price :plus:
 Post Postano: 08 ožu 2014 09:38
Pridružen: 20 sij 2014 10:43
Postovi: 54
pa ovo je zakon, mogu imat vidljiv i kalendar i broj puffova :kuc:
evic, caravela clone, ego-C Twist, ego-T, frenky v2
Protank II, Vivi nova, ce4, evod, raketna kaja, igo-l, helio, kayfun light
 Post Postano: 08 ožu 2014 10:56
Postovi: 1012
Zadnje što sam čitao je to da bi mogao izaći tek na jesen 2014.
Samo se nadam da će biti kompatibilna tuba sa eVic 1 i da će staviti neki čip koji daje barem 20W.
U svakom slučaju je moj kada izađe.
 [ 6 post(ov)a ]
Trenutno korisnika: bot* i 54 gostiju.
