 Naslov: SIGELEI legend
 Post Postano: 14 lis 2013 10:10
Dobio sam obavjest o novom modu od Sigelei-ja, nisam ga isprobao i neznam kako radi, samo prenosim informaciju:
1.SIGELEI legend has 510 and EGO thread. fit most atomizers/tanks/vaporizers/cartomizers.
2. SIGELEI legend is made of stainless steel, durable
3. SIGELEI legend can be adjusted from 3.0-6.0V volts in 0.1 volt increments.
4. SIGELEI legend can be adjusted power from 7-15 W in 0.5 watts increments.
5. Built-in OLED screen allows you to visually adjust your voltage and wattage
6. SIGELEI legend has different tubes to fit 18650,18350,18500,16340,14500,18400,and any battery you have
7.atomizer/cartomizer ohms display, wattage/voltage display, battery remaining, smoking puffs display, and smoking time are all visually showed on one oled screen, one big screen to display many functions
8. 5 Click on/off
9.power bank function to charge your mobile phone for emergency use
10. The newest technology-Gravity sensing technology in e cig industry to extend button lifetime
11. power bank function to charge your mobile phone and tablet pc
 Naslov: Re: SIGELEI legend
 Post Postano: 14 lis 2013 10:48
Pridružen: 20 ruj 2012 14:00
Postovi: 1012
Uff... :slin:
Ovo lijepo izgleda. Već me svrbi dlan...
Mislim da bi mi ovo mogao biti rođendanski ili Božićni poklon samo da izađu neki review.
 Post Postano: 14 lis 2013 15:58
Pridružen: 30 stu 2012 23:08
Postovi: 2488
Lokacija: Njemačka
meni se cini da je ovo neki klon evica....da ljepo izgleda bogme izgleda....treba vidit kad izađu recenzije kako se pokazao
 Post Postano: 14 lis 2013 19:06
Pridružen: 05 kol 2012 11:34
Postovi: 1034
Lijepo izgleda ali ne treba zaboraviti da je to sigelei a od njih nikad nista posteno...
 Post Postano: 14 lis 2013 20:01
Bas se i ne slazem da je Sigelei losa firma. Njihov zmax v2 povremeno koristim i ni jednom nije omanuo. Na V3 telescopic isto nema prituzbi.
Ovo je kopija evica s punjacem za mob...
 Post Postano: 14 lis 2013 20:12
Postovi: 1034
Zato sam i ostavio prostora za ocjenu,da je njihova mehanika u pitanju napisao bih samo s...e :)
 Post Postano: 14 lis 2013 20:21
Pridružen: 16 kol 2013 22:43
Postovi: 1083
Lokacija: Zagreb, Maksimir
Koliko sam čitao zmax v2-v3 su imali problema sa onim jednim gumbom, a ovo ako ima prsten za izbor menija strah me je i pomisliti... Meni je zmax v3 riknuo nakon 3 tjedna, otišlo nešto na elektronici, display ne radi više, sad je negdje u avionu na putu za reklamaciju. Doduše, možda je samo moje iskustvo, imam poznati voodoo sa elektronikom :)
Dalmat
Daily drive: Russian 91%, Kayfun Lite Plus V2 klonjara, FT Nemesis x 2,
Ostalo: IGO-L x 2, ZMAX v3, Vamo V5, Chi You + AIOS hibrid, ASTRO + AIOS hibrid, Russian 91% klonjara, Taifun GT + ASTRO, Evolve Kick
slika slika
 Post Postano: 15 lis 2013 00:23
Postovi: 2488
Lokacija: Njemačka
Dalmat je napisao:
ako je prsten napravljen kao na evicu onda je dobar....pisao sam baš o prstenu koji je na bazi glave....dobar je kod evica
 Post Postano: 06 vel 2014 12:09
Pridružen: 07 vel 2013 15:29
Postovi: 56
Lokacija: dugo selo
power je od 3-15W u 0.1 stupnjevima,odlicno,
 Post Postano: 06 vel 2014 12:12
Postovi: 2488
Lokacija: Njemačka
http://www.fasttech.com/forums/vapers/t ... ei-20watts
clon dna20....?
Trenutno korisnika: bot* i 54 gostiju.
