 [ 18 post(ov)a ]  Stranica 1, 2  Sljedeća
 Naslov: Lava tube V4 18650
 Post Postano: 14 lis 2013 22:33
Pridružen: 14 lis 2013 13:55
Postovi: 14
kako I sam naslov kaze dolazi mi Lava tube V4. pa me sad zanima koji tank da uzmem? za pocetak cu da koristim ce4. kojih imam par komada.
hvala
 Naslov: Re: Lava tube V4 18650
 Post Postano: 14 lis 2013 22:41
Pridružen: 20 lip 2013 23:58
Postovi: 738
Lokacija: Novigrad (Istra)
ce4 ne baš :D
ovisi ako ti se da radit sam setupove i ako da sa čime špagom ili meshom
nemesis sanblasted, nemesis, hammer
the russian, Igo L, kayfun 3.1 clone....
 Post Postano: 14 lis 2013 22:42
Pridružen: 05 kol 2012 11:34
Postovi: 1034
Sa meshom na elektronici nece dobiti nista
 Post Postano: 14 lis 2013 22:55
Postovi: 14
pa koji tank da uzmem? evo ovo pise za proizvod:
Lava tube V4 is a smart microprocessor controlled electronic cigarette,that uses the latest technology to allow you to set a range of voltages.
With its built-in three digital display there are no analog dials or potentiometers to wear out. There's no way to accidentally reset the voltage and you can make changes within seconds.
Lava tube V4 allows you to digitally dial in your favorite voltages on its mini display.
You can adjust the voltage from 3.0 to 6.0 using the built in user interface.
Lava tube V4 for 18650 high power excellent performance batteries.
Lava tube V4 PCB with 4 Amperage output limit.
Lava tube V4 with flexible 360?turning around button
Multifunction: 510 threading, fit with many kinds of cartomizers
1. Check Resistance
2. Show How much battery left on the LCD screen
3. Limited current at 4Amps
4. Chrome, black or Silver body
5. Fits for CE4 ,CE5,CE6,VIVI NOVA all kids of atomizer.
NOTE: The max working current is up to around 4.0 ampere. We limited the Atomizer Resistance to 1.3ohms, if below 1.3Ohms, the device will turn off itself!
ovdje stoji da se moze koristit CE4
 Post Postano: 15 lis 2013 00:01
Postovi: 1034
Mozes koristiti sve ali bitan je rezultat. Mozda neki protank ili cody ako ces praviti setupe
 Post Postano: 15 lis 2013 09:12
Pridružen: 28 srp 2013 12:19
Postovi: 1484
Lokacija: V.Gorica
Ma uzmi original Kanger PROTANK v2 i pari
 Post Postano: 15 lis 2013 09:43
Pridružen: 20 ruj 2012 14:00
Postovi: 1012
imand je napisao:
Slažem se sa imandom. Ili mini verziju istog.
CE4 neka stoji sa strane za nedaj Bože ali ga treba izbjegavati.
 Post Postano: 15 lis 2013 17:03
Postovi: 14
gdje da narucim Kanger PROTANK v2? gdje je najjeftinije i najbolje? i da li ima veze koliko je ohm? jel naletio sam na neke pro tank i mozes birat ohm.
hvala na pomoci
 Post Postano: 15 lis 2013 17:45
Pridružen: 08 ruj 2013 19:06
Postovi: 91
Evo imaš tu http://ego2.pl/en/kartomizery/375-clearomizer-protank-2.html dobiješ u setu 2 grijača od 2 ohma i 2.5 ohma ili
http://www.mtmstore.eu/ispariva%C4%8Di-atomizers/kanger/ispariva%C4%8D-atomizer-kanger-mini-protank-bcc-stakleni-e-cigarete
 Post Postano: 15 lis 2013 18:04
Pridružen: 05 svi 2013 10:13
Postovi: 1899
Lokacija: Zagreb, Gajnice
slaganje setupa je prilično jednostavno. Trebaš samo silicu, kantal i par minuta gledanja youtube.
Ne obračaj pažnju na ovo grijač 2 ili neznam kolko ohma. Sve to treba presložiti (a nije niti problem niti košta više od par kuna)
Tvornički setupovi su nepouzdani. Ima li tragova mašinskog ulja ili drugih stranih čestica :conf: , hotspotova :conf:
Ne treba se time opterečivati. Presložiš za par minuta i par lipa/kuna i točno znaš na čemu si.
