 [ 23 post(ov)a ]  Stranica 1, 2, 3  Sljedeća
 Naslov: GENISIS Automatic (i druga unapredjenja)
 Post Postano: 18 pro 2011 19:17
Pridružen: 03 ruj 2011 22:08
Postovi: 13
...pošto sam temu izbacio na "druga dva" foruma, red je i da se ovde javim.
samo nemam vremena za prevod:( ko razume engleski neće mu biti problem, ostali zainteresovani - Google translator može pomoći.
http://imageshack.us/photo/my-images/41 ... matic.jpg/
hi vapers!)
first of all, let me introduce my self, since i didn't post in this forum, much (i was busy), but i have been reading it a lot.
i'm petar k (28), and i'm graphic designer, and i like other creative areas too, like modding, of course I'm a vaper for more than two ears now, and i like e-smoking very much. but, i think there are many things about e-cigs that have to be improved.
in this project, i was about to, at least try, to make this "thing" automatic, since it is crucial for the vaping experience (imo). i was experimenting with this system, and with some other systems which will be implemented in the GENISIS Automatic mod, for last few mounts. and, i think i made it.
so, these are the next improvements:
- mechanical automatic switch
- the mesh oxidation is not needed(!)
- wire fasteners can be scrowed by fingers - without any tools
(also, the position/height of the screws/fasteners could be changed, depending on coil size - number of wraps)
- better wicking
- no gunk
the mod characteristics:
- made from only 10 - 12 different parts
- fitted for 14*** batteries
- dimension: ~130x15mm (could be shortened for 15mm if using only 14500 batteries)
- weight: around 100g
- ~3ml tank
- drip-tip (integrated) mouthpiece
- parts made from: steel, plexyglass, inox, aluminium, messing.
- silicon gum mouthpiece
- push in battery cap, depending on battery size
- no soldered parts
- no wires
mechanical automatic switch is working by using (conscious or unconscious) gesture of pressing (e)cigarette mouthpiece/filter by mouth/lips, or by teeth if needed. it doesn't need some great lips pressure to make a contact. it's simple and reliable...
more info, photos and videos - soon.
 Naslov: Re: GENISIS Automatic (i druga unapredjenja)
 Post Postano: 18 pro 2011 22:59
Petre Petre kak se ti ne znas hvalit.
 Post Postano: 18 pro 2011 23:04
hi, viđeno, a zašto tloiko o tome, stvar koja se kupi, nabije na gubec i pariš.
Šalamala stvar je savršena :hi:
 Post Postano: 18 pro 2011 23:09
Pridružen: 03 ožu 2011 16:24
Postovi: 1370
Lokacija: Zagreb,Krapinhagen
Jako lijepo,i sviđa mi se kaj ne moraš imati pauze između udisaja što bi mi dobro došlo kad sam živčana,a pare ko u priči :plus:
 Post Postano: 18 pro 2011 23:16
sanja je napisao:
Osim SAVRŠENOG avatara, a zakaj si nervozna?
Imaš sve kaj ja nemam.
Mužeka.
Vikendaču v zigorju.
Auto novi.
Nofcih ko kenje.
Nemaš Taru. btw ja imam dve
kaj ti fali?
 Post Postano: 18 pro 2011 23:20
Postovi: 1370
Ono šesto i jedna Tara :blje:
 Post Postano: 18 pro 2011 23:47
Postovi: 13
hvala narode. žao mi je što ne mogu detaljnije opisati ovaj uredjaj, iz očiglednih razloga:(
ovime sam samo želeo da vam pokažem da je moguće bez problema i maksimalno pouzdano, pariti genisis paljen s' (mehaničkim) automatskim prekidačem. a i proizvodnja je u toku:= (ovo smem da kažem ovde?)
sanja, ako ti kontinuirano "disanje" pare smiruje živce - za tebe više neće biti nervoze;)
 Post Postano: 19 pro 2011 00:14
Pridružen: 03 ožu 2011 19:03
Postovi: 683
Lokacija: Ispod Sljemena!
Ovdje se sve smije.. osim onog što se ne smije! :belj:
 Post Postano: 19 pro 2011 00:27
Sve se smije, osim čitat DODO-ine postove, a dapače ovo je zanimljivo. :joj:
 Post Postano: 19 pro 2011 02:50
Pridružen: 20 ruj 2011 03:34
Postovi: 525
petar k je napisao:
Very interesting.... ajd javi kad proizvodnja bude da si uzmem.
Trenutno korisnika: Google [Bot] i 4 gostiju.
